1995 Chevy Caprice Hard Cold Start
BOBBYP6
have a 95 chevy caprice wagon 5.7 v8 mpi engine. the problem is hard to start when engine is cold.
starts fine when engine is warm . runs fine once started . any suggestions. had complete tune up 15,000 miles ago . car has 130,000 miles on it.
maybe fuel pump?
fuel regulator?
fuel filter??
Modulator???
thanks for your help bob
Oct 28, 2007 at 10:48 AM
  • 75,988 POSTS
Sounds fuel related-okay check the coolant temperture sensor could be acting up it takes the place of a choke on a carbuerator for initial starts, also check out the fuel filter/air filter.
Oct 28, 2007 at 12:00 PM
Suggested Repair
Check the coolant temperature sensor, which controls cold-start enrichment, and also inspect the fuel filter and air filter.
Conversation Summary
The owner of a 1995 Chevrolet Caprice wagon with a 5.7 MPI V8 reports hard starting only when the engine is cold; it starts and runs fine once warm. A tune-up was done about 15,000 miles earlier. The expert says the issue sounds fuel-related and recommends checking the coolant temperature sensor, fuel filter, and air filter.
