fuel leak on/around gas tank
CHEVROLET CAPRICE
CHEAPSKATES239
1989 Chevy Caprice, 4-door, auto transmission, a/c, 305V8, 165,000 miles.
Notice strong gas odor, but only after driving. Comes from the back. Looked under car (after driving), (only while crouching by the side of the car, did not go underneath) -- no gas on the ground. But noticed splotches of wetness (i.e., gas) on the tank underside, toward the front of the underside of the gas tank, around the middle -- extending from the leading edge. It looked like it had been seeping from somewhere on the upper side or the front side of the tank to that spot. I imagine there's a leak around a gas line fitting, or any possible wiring penetrations.
What could it be and how easy/expensive is it to fix if I take it in? Is the fuel line welded to the tank, or is there some gasket/fitting/rubber part used for interface? (Mechanics non-committal on the phone, claim it could cost as much as $800-$1,000, if they have to also replace the brake lines, which they claim may be nearby; that seems way off the wall).
Thanks. John W.
Jul 23, 2007 at 12:52 PM
2CARPRO JACK
  • 11,533 POSTS
There are a couple of hoses and a rubber seal for the tank unit that might be leaking. Does it do it all the time or only when the tank is very full? If full then the seal for the tank unit might be the problem, otherwise could just be a few fuel lines that need replaced
Jul 24, 2007 at 1:09 AM
CHEAPSKATES239
[quote:4fc09ddd8d="2CarPro Jack"]There are a couple of hoses and a rubber seal for the tank unit that might be leaking. Does it do it all the time or only when the tank is very full? If full then the seal for the tank unit might be the problem, otherwise could just be a few fuel lines that need replaced[/quote:4fc09ddd8d]
It happens all the time after driving, so it's a line, probably supply line (higher pressure) at the fitting. Do you agree that that is not an expensive repair -- can just a section of the line be replaced (cut and weld), does the tank need to be dismounted?
Jul 24, 2007 at 6:07 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, the tank will have to come out to fix it.Depending on which line it is, pressure or return will depend on the price to fix it.There are alot of diffenernt repair pieces out there that can be spliced in.
Jul 25, 2007 at 12:40 AM
