1996 Chevy Caprice backfire
1996 CHEVROLET CAPRICE
160,000 MILES • V8 • 2WD • AUTOMATIC
LUKEN315
caprice backfires out exhaust under load and has loss of power. after backfire, car takes off and accelerates intermittently. set code for o2 sensor slow response but check engine light went off, also set code for random misfire on the highway but went off. i did plugs and wires and cleaned grease off opti spark distrubtor and the car has a lot more power but still has the problems. what can i do to fix my backfiring and unusually slow caprice?
Mar 3, 2009 at 3:25 PM
  • 110,244 POSTS
Hi:
Have you replaced the O2 sensor? Also, have you checked to see if the catylatic converter is partially plugged? finally, a common cause of a backfire is a vacuum leak. Check closely for them and make sure the intake gasket isn't leaking.
Mar 6, 2009 at 10:34 AM
