1995 Chevy Caprice intake backfire
122,000 MILES • V8 • 2WD • AUTOMATIC
9CLT1
i have replaced plugs, opti spark, mass air flow, computor, and o2 sensors but still have a back fire comming from the intake air filter. this hapens at a high rmp. also idels rough and has no power like a lt1 should. the drivers side old plugs were black but passengers side were good. i do see some improvement since the opti and plugs were changed but still that darn back fire from the air filter.
Dec 23, 2007 at 12:05 PM
GENUINE1D
  • 9 POSTS
[quote:8d7a57c4ed="9clt1"]Engine problem
1995 Chevy Caprice V8 Two Wheel Drive Automatic 122000 miles
i have replaced plugs, opti spark, mass air flow, computor, and o2 sensors but still have a back fire comming from the intake air filter. this hapens at a high rmp. also idels rough and has no power like a lt1 should. the drivers side old plugs were black but passengers side were good. i do see some improvement since the opti and plugs were changed but still that darn back fire from the air filter.[/quote:8d7a57c4ed]
I had the same problem, Try changing the cap and rotor.
Dec 23, 2007 at 1:52 PM
  • 75,988 POSTS
Go back to index
Inbox :: Message
To: rasmataz
Posted: Sun Dec 23, 2007 11:25 pm
Subject: air filter back fire
i have replaced plugs, opti spark, mass air flow, computor, and o2 sensors, fuel filter but still have a back fire comming from the intake air filter. intake bolts are tight, exhast is tight. this hapens at a high rpm. also idels rough and has no power like a lt1 should. the drivers side old plugs were BLACK but passengers side were good. i do see some improvement since the opti and plugs were changed but still that darn back fire from the air filter is still there. could the cat be bad. no check engin light on.
1995 chevy caprice. LT1. 9C1. 5.7L
122.500 miles
HELP!
Could be a problem with excessively rich or lean mixture. Sparkplugs with wrong heat range, excessive carbon/hot valves and Ignition timing
Also have the throttle position sensor and fuel pressure check-look for vacuum leak
Dec 23, 2007 at 3:39 PM
9CLT1
[quote="rasmataz"]Go back to index
it was a bad wire coming off the coil to the distributor
Dec 24, 2007 at 3:52 PM
