1991 Chevy Caprice Car runs in park. Buckles,backfires,shut
KYLES91CAPRICE
Engine Performance problem
1991 Chevy Caprice V8 Two Wheel Drive Automatic 100xxx miles
I have a 91 caprice with a 5.0 305 motor. my problem is that my car starts up and runs in park. but once i take it out the drive way and press down on the gas, the car hesitates, buckles, backfires, shuts off. and sometimes has a pinging or knocking sound after it has stalled out. I changed a few things that i thought might have been the problem but no luck with any. i need help and dont know what to look for or check next.
a list of what i have changed and replaced.
spark plugs, wires, ignition coil, pickup coil, ignition module, fuel filter, rebuilt throttle body and injectors, pcv valve, coolant temp sensor, timing chain and gears, fuel pump and stainer, and throttle position sensor, switched out the pcm and made no differece. and there is no engine light on.
if you have any ideas what it might be ill be very thankful. thanks for reading and your response.
Dec 27, 2009 at 2:50 PM
  • 75,988 POSTS
Hi kyles91caprice, Welcome to 2carpros and TY for the donation and selecting us as your auto repair site Feel free to ask questions at anytime and Merry Christmas and a Happy New Year 2010
Your probable causes here could be one of the following:
Oxygen Sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Dec 27, 2009 at 7:18 PM
