1996 Chevrolet Camaro Alarm No Start
CLANGMAN
I PUT A NEW STARTER ON MY 96 CAMARO RS 165,000 MILES 3800 SERIES ENGINE AND NOW MY FACORTY CAR ALARM IS GOING HAYWIRE AND MY CAR WON'T START. IS THERE ANYWAY THAT I CAN DISCONNECT MY ALARM? IF THAT'S NOT THE PROBLEM THEN WHAT IS IT?
Jun 27, 2007 at 7:50 AM
E40WATER12
  • 522 POSTS
Try discounting youre Neg post on youre battery, wait 5-8 mins, Then hook it up see what happens. If that doesnt fix it, Just make sure youre connections are properly connected on the starter.
GoodLuck.
Jun 28, 2007 at 9:59 PM
Suggested Repair
Disconnect the negative battery cable, wait 5 to 8 minutes, then reconnect it to reset the alarm. If the car still will not start, verify that the starter electrical connections are secure and correctly installed.
Conversation Summary
The owner of a 1996 Chevrolet Camaro RS with a 3800 engine said the factory alarm began acting erratically and the car would not start after a starter replacement, and asked whether the alarm could be disconnected. The expert recommended disconnecting the negative battery cable for 5 to 8 minutes and reconnecting it, then checking that the starter connections are properly connected if the problem remains.
