1980 Chevy Camaro Park Light Out
DASCH
1980 Chevy Camaro 130,000 miles 350 v8. Park light along with fender light will not work only on passenger side. I've replaced the bulb socket, replaced the bulb, nothing. The headlight,turn signal,4 ways work ok. Turn signal and 4 ways are dimmer on the passenger side. This is up front the back works fine. I recently replaced the altenator and afterwards for a few minutes the park light did work and was not dim at all. Then it went back out. Thanks in advance for any help.
Oct 19, 2007 at 7:22 AM
2CARPRO JACK
  • 11,533 POSTS
Soundslike you have a bad ground on that side of the car
Oct 19, 2007 at 8:33 AM
DASCH
Do you think it would be worthwhile to install a new ground on that side? Thanks.
Oct 19, 2007 at 9:16 AM
2CARPRO JACK
  • 11,533 POSTS
Might not have to replace the entire thing, could just be a poor/dirty connection
Oct 20, 2007 at 12:41 AM
Suggested Repair
Inspect and clean the passenger-side ground connection. A poor or dirty ground may be causing the out park and fender lights and dim signals, so the entire ground may not need replacement.
Conversation Summary
On a 1980 Chevy Camaro, the passenger-side front park and fender lights do not work, and the turn signals and hazard lights are dimmer on that side. Headlights, signals, and the rear lights otherwise work. The park light briefly worked normally after an alternator replacement, then failed again. The expert attributed the problem to a bad ground and suggested checking for a poor or dirty connection rather than necessarily replacing the entire ground.
