1979 Chevy Camaro Turn Signals Dead
WALSH4ND
My car is 1979 Chevy Camaro with a 350. I recently bought the car and have been trying to repair the turn signals. None of the rear bulbs light up and the system does not make the clicking sound. I have replaced the thermal flasher, the fuse, and all the bulbs. Where should I check next for my problem? Thanks for any help!
Apr 24, 2007 at 2:57 PM
  • 75,988 POSTS
[quote:c20e93d56a="walsh4nd"]My car is 1979 Chevy Camaro with a 350. I recently bought the car and have been trying to repair the turn signals. None of the rear bulbs light up and the system does not make the clicking sound. I have replaced the thermal flasher, the fuse, and all the bulbs. Where should I check next for my problem? Thanks for any help![/quote:c20e93d56a]
Bad ground and could be the switch itself.
Apr 25, 2007 at 12:20 PM
Suggested Repair
Check for a bad ground and inspect the turn signal switch itself.
Conversation Summary
The owner of a 1979 Chevy Camaro with a 350 says the turn signals do not work: the rear bulbs do not light and there is no clicking sound. The thermal flasher, fuse, and all bulbs have already been replaced. The expert suggests a bad ground or a faulty turn signal switch.
