1991 Chevy Camaro Turn Signal always on when headlights are
1991 CHEVROLET CAMARO
179,000 MILES • V8 • 2WD • AUTOMATIC
ULOTHRIX
My right turn indicator light stays on (no blinking) when I turn my headlights on. It seems to work (blink) normally when turning, but then just stays on after the flasher turns off. When my headlights are off, my indicators work normally. I have replaced the flasher, but it didn't fix the problem. The fuses are also fine. All bulbs are fine. Hazards work as intended. Could you please let me know what else to try? Thank you!
May 26, 2009 at 8:32 AM
RACEFAN966
  • 5,029 POSTS
Well with what you have discribed and with what I can find it looks like you may have a headlight switch problems. We can do a couple of tests if you have a test light or multi meter to be sure. If you would like to do a couple of test I first need to know if your Camaro is a RS or Z28 model as the wiring is different between the two. Let me know what you would like to do and we will go from there.
May 27, 2009 at 3:41 AM
ULOTHRIX
It's a 1991 Camaro V8 RS. I do indeed have a multimeter. Let the testing begin!
Thanks!
May 27, 2009 at 6:49 PM
RACEFAN966
  • 5,029 POSTS
Sorry I forgot to ask which side is doing this and is it the front or rear turn? Sorry kinda important to know can't believe I forgot to ask that.
May 28, 2009 at 3:31 AM
ULOTHRIX
Hi, it's the right turn signal, the indicator on the dash that stays on when the headlights are on. None of the outside indicator lights are affected. Hope this helps!
May 28, 2009 at 4:50 AM
RACEFAN966
  • 5,029 POSTS
Ok what I need you to do is check the dark blue wire coming from the turn signal socket and see if there is power there. Let me know what you find ok. Also check the brown wire for power and then if you would check the black wire and make sure it is grounded well. Let me know what you find and we will go from there.
May 29, 2009 at 3:11 AM
