2002 Chevy Camaro Replacing Front Turn signal lamp
2002 CHEVROLET CAMARO
51,000 MILES • V8 • 2WD • AUTOMATIC
DENNYRDOMOVAN
How do I replace the driver side front turn signal lamp?
Jan 6, 2008 at 2:46 PM
SQUIRRELISHERE
[quote:119a8c0c4a="dennyrdomovan"]Electrical problem
2002 Chevy Camaro V8 Two Wheel Drive Automatic 51000 miles
How do I replace the driver side front turn signal lamp?[/quote:119a8c0c4a]
You have to take out the headlight first. It's held on to a bracket using a 10mm bolt. Once you take the bolt out, you slide the headlight out a bit, and it should unhook from 2 tabs. Once you move the headlight out of the way, you have easy access to the side markers.
Jan 6, 2008 at 4:00 PM
