1998 Chevy Camaro Right Rear Turn Signal
125,000 MILES • V8 • 2WD • AUTOMATIC
KDKANE007
I replaced the rear right blinker bulb with a new one. To test it, I switched that blinker to on and all the bulb does is stay on rather than blink. The left blinker works just fine. What could be the problem and what can I do to correct it so that the right blinker can actually blink?
Apr 11, 2008 at 3:39 AM
ARTMANG
  • 61 POSTS
make sure the bulb is the correct one.put the blinker on then move the bulb around adjusting play around with it and wires and see if it works somehow if it does then something there is lose or not making contact correctly maybe will need new socket .also have someone play with the turn signal lever moving it it around and see if it blinks if it does then ur prob is there.possibly socket no good or loose wire round it.also try new flasher.looks like cylinder on fuse box.
Apr 11, 2008 at 11:26 AM
