1997 Chevy Camaro turn signal flashers
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMDER
I was wondering where to find the turn signal flashers on
this auto.My right blinker will not work although all bulbs are good and it works with the hazard lights engaged.
I think it needs replaced.thanks.
Feb 2, 2008 at 5:38 AM
PWCBOY423
Howdy, I just replaced mine the other day on my 1997 RS Convertible. It's under the dash on the right hand side of the steering wheel. You will have to take the lower dash panel off to access it. It's secured with a pressure clip.
Mar 1, 2008 at 2:59 PM
GUITAR101
  • 5 POSTS
I had a '99 that had the same problem. There are two bulbs for each turn signal, and each is a different make and model. The easiest one to find is a small one that can be accessed from under the hood. The other is larger and will likely require you to go under the car and take off the covering behind the air deflector. If the hazard lights work, it's probably not the flasher, but if it is, it is located under the steering column.
Mar 5, 2008 at 5:15 AM
