Passenger side park light
CHEVROLET CAMARO
DASCH
1980 Chevy Camaro 130,000 miles 350 v8. Park light along with fender light will not work only on passenger side. I've replaced the bulb socket, replaced the bulb, nothing. The headlight,turn signal,4 ways work ok. Turn signal and 4 ways are dimmer on the passenger side. This is up front the back works fine. I recently replaced the altenator and afterwards for a few minutes the park light did work and was not dim at all. Then it went back out. Thanks in advance for any help.
Oct 19, 2007 at 7:22 AM
2CARPRO JACK
  • 11,533 POSTS
Soundslike you have a bad ground on that side of the car
Oct 19, 2007 at 8:33 AM
DASCH
Do you think it would be worthwhile to install a new ground on that side? Thanks.
Oct 19, 2007 at 9:16 AM
2CARPRO JACK
  • 11,533 POSTS
Might not have to replace the entire thing, could just be a poor/dirty connection
Oct 20, 2007 at 12:41 AM
