Try checking the fuel pressure to rule out the pump, then we'll go to igntion system looking for spark-do you know how to do this.[/Quote:56e28d7ed6]
u think it might be my wires? Because I just did my spark plugs. And the only thing I can think of is ( my fuel filter or the gas pump) ignition fuse perhaps but how to check they arent seethrough. A lil bit of guide wont hurt if u please. Ill apreciate it very much. My uncle said something about the ignition coil paks but how to know if they're bad?[/Quote:56e28d7ed6]
Try this check for a snapping blue spark-not yellowish with a plug wire disconnected and grounded to the engine while cranking it over-do you have it. I need to know this before we continue there's a reason to it before we get to the hard ones. Start or No start[/quote:56e28d7ed6]
sorry I was out for a few days. My car still here ok I checked the fuel pump like u told me to, when I turn the key to the on position u could hear the pump work, so I disconected the hoses but not the power just to see if it was pumpin gas but it turned out to a no no. So I changed the relay. But that was a nono. Now I remember u said something about checking for spark. Why? And how do i.?
Tuesday, September 4th, 2007 AT 7:58 PM
