1981 Chevrolet Camaro Gas Gauge Stuck
DNULNARTS
i have a 1981 camaro with a few thousand miles on the rebuilt 350 and the gas gauge is stuck at just above a 1/4 of a tank. whats the problem. is the float stuck?
Jun 10, 2007 at 3:44 PM
E40WATER12
  • 522 POSTS
Sounds to me youre sending unit is gunked up, With corriosion. Either Can be cleaned or, My need a new gas tank and sending unit.
Jun 10, 2007 at 6:24 PM
Suggested Repair
Inspect the fuel sending unit for corrosion or buildup. Clean it if possible, or replace the gas tank and sending unit if cleaning does not restore the gauge.
Conversation Summary
The owner of a 1981 Chevrolet Camaro with a rebuilt 350 reports the gas gauge stuck just above a quarter tank and asks if the float is stuck. The expert says the sending unit is likely gunked up with corrosion and can be cleaned, or the gas tank and sending unit may need replacement.
