1979 Chevy Camaro Rear Brakes Stuck
JBRANN
1979 camaro with 305 and 81000 miles. Replaced rear drums and bled the entire brake system but the brake light stays on. The left rear brakes are weak when pressure is applied and the right rear is extremely tight and will no longer move. When replacing the shoes I replaced the the brake hardware kit and both drums were replaced with new ones. Any help would be appreciated with this because I'm officially stumped. Thank you.
Mar 2, 2007 at 6:45 AM
  • 75,988 POSTS
[quote:a39a3e676b="jbrann"]1979 camaro with 305 and 81000 miles. Replaced rear drums and bled the entire brake system but the brake light stays on. The left rear brakes are weak when pressure is applied and the right rear is extremely tight and will no longer move. When replacing the shoes I replaced the the brake hardware kit and both drums were replaced with new ones. Any help would be appreciated with this because I'm officially stumped. Thank you.[/quote:a39a3e676b]
Bleed the M/C and go on each wheel-light still there-check the combination valve/switch-proportioning/metering Valve. Your brake is not equalized for the lite.
Mar 2, 2007 at 6:57 AM
HONDAMIKE
  • 71 POSTS
Also, make sure that the brake shoes were adjusted evenly.
Nov 27, 2010 at 7:53 AM
Suggested Repair
Bleed the master cylinder and each wheel. If the brake light remains on, inspect the combination valve/switch and the proportioning or metering valve, since the brakes are not equalized. Also adjust the rear brake shoes evenly.
Conversation Summary
A 1979 Chevrolet Camaro owner replaced the rear drums, shoes, and hardware and bled the brake system, but the brake light stayed on. The left rear brake was weak while the right rear was extremely tight and would not move. Experts advised bleeding the master cylinder and each wheel, checking the combination valve/switch and proportioning or metering valve if the light remains, and adjusting the shoes evenly.
