1996 Chevy Camaro Popping After Accel
Z28_GUY
hey guys!
i have a 96 chevy Camaro v8 5.7 6 speed with about 155,500 miles on it. for awhile now i have noticed that when i rev my engine up(usually while in nuetral but sometimes while driving) i get a popping/choking sound while the engine is returning to idle speed. im not really sure what it is. the car has a problem keeping oil pressue but i have never noticed a leak.(probably bad clearances, so i use 10w-40 oil in it) because of the low oil pressue my lifters or something else in the valve train has been ticking for awhile. not sure if that could have anything to do with the exhaust noises.
could timing also be a contributer to what i am experiancing.
i would really appricaite any help, theroys, or advice that anyone could give me.
Feb 25, 2007 at 6:45 AM
CHEVY22
  • 1,375 POSTS
tell you the truth ths is a peoblem that would be hard todiagnose without really lloking at it , but if you do have a real oil pressure issue this may be the cause , i would do a manula pressure test which is easy to find what the oil pressure really is and go from there were here to help any further is you need it
thanks jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 6:54 AM
Suggested Repair
Perform a manual oil pressure test to confirm the actual pressure. Low oil pressure may be related to the valve-train ticking and the popping or choking on return to idle; continue diagnosis from those results.
Conversation Summary
The owner of a 1996 Chevrolet Camaro 5.7 reports popping or choking as the engine returns to idle after revving, along with low oil pressure and valve-train ticking. The expert says the problem is hard to diagnose remotely and recommends a manual oil pressure test before proceeding.
