1992 Chevrolet Camaro No Compression
MGL01
i just repace the manifold lower gasket i put it back together now it dont start and no compression timing is right anyone have idea? thanks
Jan 9, 2006 at 8:33 PM
2CARPRO JACK
  • 11,533 POSTS
sounds like the lifters need to bleed down. Also if you removed the pushrods they are different lengths, be sure they are in the right spots
Jan 10, 2006 at 5:46 AM
Suggested Repair
Allow the lifters to bleed down. If the pushrods were removed, reinstall them in their original positions because they are different lengths.
Conversation Summary
A 1992 Camaro V6 has no compression and will not start after the lower intake manifold gasket was replaced, despite correct timing. The expert suggested the lifters may need to bleed down and warned that removed pushrods must be returned to the correct locations because they differ in length.
