1997 Chevrolet Camaro Stalling
DARSTEIN
1997 Chevrolet Camaro, 72,000 miles, 3.8 L V6
It stalls sometimes. It doesn't seem to matter if it is running at highway speed or idling. It just shuts off. I had the EGR valve replaced because the error code indicated that was the problem, but it did not correct the problem. I would appreciate any feedback or experience you may have with this problem. Thank you in advance for your assistance.
Aug 26, 2007 at 2:05 AM
MERLIN2021
  • 17,250 POSTS
Are there any other symtoms? If no try replacing the crankshaft position sensor. If yes like lights or gauges out let us know!
Aug 26, 2007 at 4:47 AM
DARSTEIN
[quote:04593afe8a="merlin2021"]Are there any other symtoms? If no try replacing the crankshaft position sensor. If yes like lights or gauges out let us know![/quote:04593afe8a]
I replaced the crankshaft sensor and the car has been trouble free for a month.
thank you the great advice.
Sep 29, 2007 at 12:28 PM
Suggested Repair
If there are no other symptoms such as lights or gauges going out, replace the crankshaft position sensor. An EGR valve replacement did not fix the stalling.
Conversation Summary
A 1997 Chevrolet Camaro with 72,000 miles stalled intermittently at idle and highway speed. An EGR valve replacement based on a fault code did not solve it. The expert suggested replacing the crankshaft position sensor if no other symptoms were present. The owner replaced the sensor and reported the car ran trouble-free for a month.
