1997 Chevy Camaro Engine Stall
97,000 MILES • V8 • 2WD • MANUAL
ORTEGATN
I have just a 1997 camaro that I just purchased used. THe individual that i bought it from said it was missing the thermostat they could not tell me why. I was driving home for the first time last night and the car stalled out. I noticed that the Temparture gauge never got up to the proper temperature. I assume this is because of the missing thermastat. But at idle i noticed the temparature raised up to 180 degrees and while driving it droped dramatically, botoming out the gauge I beleive this is because of the air flow from the radiator. Also there was white smoke coming out of the heater vents fogging all of the windows. This i beleive is a leak in the heater core. But I am puzzled about the car stalling out. I have to drive down a hill with a 19% grade and on the way down is when it stalled. after a few minutes it would start again briefly and stall.
Nov 19, 2009 at 5:24 PM
RACEFAN966
  • 5,029 POSTS
Ok first off you need to put in the correct thermostat (195 degree) and then we can do some testing. Also the smoke inside probably is the heater core so plan on replacing that too. We can't really do any testing with the thermostat missing as the sensors won't get to proper operating temp. Your mpg should be really low too because of the missing thermostat.
Nov 20, 2009 at 2:24 AM
ORTEGATN
I have both the parts on order they should be here in a week. thanks for your help
Nov 20, 2009 at 11:03 PM
RACEFAN966
  • 5,029 POSTS
Ok once you get them in then see how it runs and if things still aren't normal then get back to me with what problems you are having and we will go from there.
Nov 21, 2009 at 12:41 AM
ORTEGATN
I put in all of the new parts and there seems to be no problems with the cooling. but it is still stalling. If I try to start it right away it wont start. If i wait a for a while it will start like normal. I replaced to battery and the car runs is still stalling. It was a gel type battery when i replaced it the voltage gauge read 15 volts. it drops to 13 volts after running for about a half hour, this is about the time it will stall out. the car will restart right away since i replaced the battery.
Dec 7, 2009 at 2:21 AM
RACEFAN966
  • 5,029 POSTS
Ok so tell me how old is the fuel filter? I would like you ohm the coolant temp sensor too if you would. Just simply unplug it and ohm it and do this when the car is cold. Then get back to me with the ohms and the air temp at the the time.
Dec 7, 2009 at 4:13 AM
ORTEGATN
Ok i was able to check the ohms today they where 500 ohms and it was abot 50 degrees out. I am not sure when the fuel filter was changed i bought the car used so I can only assume that it is the original. I was able to pull two codes off the OBD II they where P1371 to few IC/low resolution 4x puls and P0441 evap system incorrect no purge flow. I am starting to think that this is a seperate problem form the cooling system though. I am still not sure what is going on.
Dec 10, 2009 at 12:34 AM
