1967 Chevrolet Camaro Pedal to Floor Fix
Steve
According to the service manual the mc should have check valves in the outlet holes. I noticed that when bleeding the mc that in the chamber feeding the front brakes that upon releasing the pressure there is a, what I'll call a small geyser, like squirt that comes from the bottom of the chamber. This does not occur in the chamber feeding the back brakes. This squirt is not air and it appears to me is fluid returning to the chamber. Do you think this indicates that the hole feeding the front brakes does not have a check valve then?
Steve
Steve
Suggested Repair
Install a drum-brake master cylinder that has residual-pressure check valves in the outlet ports, as the service manual specifies. Aftermarket units without those valves allowed fluid to return from the front circuit and left the pedal nearly on the floor with little front braking. Confirm check valves are present before buying, then bench-bleed and install the cylinder.
Conversation Summary
A 1967 Chevrolet Camaro with manual four-wheel drum brakes had a pedal that traveled nearly to the floor, weak rear braking, and no useful front braking. The dash brake light stayed on. The owner had replaced the master cylinder, lines, hoses, wheel cylinders, shoes, and distribution block, adjusted the shoes, verified pushrod free play, and bled the system thoroughly. An expert suggested a stuck shuttle in the distribution block, bypassing that block, recentering the valve, and checking the shared brake-light circuit. The owner later found fluid returning into the front master-cylinder chamber and learned many replacement drum-brake masters omit residual check valves. A Cardone master cylinder built with those valves restored a high, firm pedal and normal braking.
