1995 Chevrolet Camaro No Brakes
CMILES1943
  • 6 POSTS
I disconnected the brake lines from the abs system to do a motor swap now I have no brakes and have tried to bleed them but this does not work. ( doing it the same as the older cars. Help please.
Jan 12, 2006 at 5:11 AM
2CARPRO JACK
  • 11,533 POSTS
take it to a brake shop
Jan 12, 2006 at 9:49 AM
CMILES1943
  • 6 POSTS
[quote:b31fac22db="2carprojack"]take it to a brake shop[/quote:b31fac22db]
I would like to be able to do plus a tow truck and shop could cost big bucks.
Jan 13, 2006 at 8:20 AM
CMILES1943
  • 6 POSTS
[quote:058c06d649="cmiles1943"][quote:058c06d649="2carprojack"]take it to a brake shop[/quote:058c06d649]
I would like to be able to do plus a tow truck and shop could cost big bucks.[/quote:058c06d649]I know I can do that , Why are you on here????
Jan 13, 2006 at 8:21 AM
Suggested Repair
Take the vehicle to a brake shop for professional brake service after the ABS lines were disconnected.
Conversation Summary
The owner of a 1995 Camaro disconnected the brake lines from the ABS system during a motor swap and then had no brakes. Bleeding the system the same way as on older cars did not restore braking. The expert recommended taking the vehicle to a brake shop. The owner preferred to repair it personally because of towing and shop costs and questioned the recommendation.
