1994 Chevrolet Camaro Bogging When Hot
AZNEAU28
i have a 94 z28 with a 6 speed, lt1. has a lt4 cam headers and cai, i did not put this on. for the question, when the car heats up and i punch on the gas it does like a skipping and bogging down type deal. i never worked on fuel injection so thats why im here. the closest thing i can compare it too, is when you run really lean on a carbed 350. and it only does this when it approaches, 210 degrees.
Jul 31, 2007 at 5:58 PM
CLY
  • 308 POSTS
I would start by checking the plug wires. Also take a look at that coil wire. I had one awhile back that was doing something similar and it just needed a major tune-up...
Cly
Jul 31, 2007 at 9:54 PM
Suggested Repair
Inspect the spark plug wires and the coil wire, and perform a major tune-up if needed.
Conversation Summary
The owner of a 1994 Chevrolet Camaro Z28 with an LT1 reports skipping and bogging under throttle once the engine approaches 210 degrees, similar to a lean condition. The expert suggests checking the plug wires and coil wire and performing a major tune-up.
