2002 Chevy Camaro car cranks but will not start
2002 CHEVROLET CAMARO
52,000 MILES • 6 CYL • 2WD • AUTOMATIC
DIANNAWATTS
the camaro cranks but will not start. No porblem with it prior but all of a studden would not start. Can not afford to pay for diagnostic. Lost job and almost home. PLease help the car is stuck at college with our daughter
Nov 25, 2009 at 2:13 AM
JDL
  • 16,098 POSTS
Welcome to the forum. When you turn the key on, no crank, can you hear the fuel pump run for a few seconds. If not, you'll have to check the fuel pump circuit. You need to use a gage and check fuel pressure. Also, you can pull a spark plug wire loose, use known good plug or spark tester in the boot, ground metal part of tester or plug to metal part of engine, with engine cranking, watch for spark at the tip of plug. Vehicles are costly to own and maintain, no way around it.
Aug 17, 2019 at 10:12 AM
