1998 Chevy Camaro Replacement of Intake Manifold Gasket
1998 CHEVROLET CAMARO
54,612 MILES • 6 CYL • 2WD • AUTOMATIC
ROSY515
  • 5 POSTS
I would like to know if it would be standard procedure for the oil and oil filter to be changed after the Intake Manifold Gasket and lower manifold gasket is replaced if there was a possibility the oil could be contaminated by a leaky gasket?
Jul 30, 2009 at 6:20 AM
MERLIN2021
  • 17,250 POSTS
I have seen it all...it would be a common sense proceedure at least. Not to say some garages have common sense..or not...A good shop would check the oil at least!
Jul 30, 2009 at 7:26 AM
ROSY515
  • 5 POSTS
Would they check the oil levels or for contaminates? And why would they change the oil and not the filter? Are dealership service departments usually good garages?
Jul 30, 2009 at 9:48 AM
MERLIN2021
  • 17,250 POSTS
What happens at MOST dealers, is the mechanics do the mechanical work, then the lower paid helpers do the oil changes, and he may have "forgot" the filter...seen it happen.
Jul 30, 2009 at 10:05 AM
ROSY515
  • 5 POSTS
would the lower paid worker reassemble the engine?
Jul 30, 2009 at 11:53 AM
ROSY515
  • 5 POSTS
would enough contaminate to seize the engine remain in the filter?
Jul 30, 2009 at 11:54 AM
MERLIN2021
  • 17,250 POSTS
Antifreeze and engine bearings DO NOT like each other very much, it would take a bit of driving, and you would see smoking long before it actually siezed. However, if the engine oil and filter were not changed, and it was 2-3 quarts overfull, it would sieze almost immediatly.
Jul 30, 2009 at 12:04 PM
ROSY515
  • 5 POSTS
thank you for your help
Jul 31, 2009 at 2:50 AM
MERLIN2021
  • 17,250 POSTS
Your welcome.
Jul 31, 2009 at 4:23 AM
