2002 chevy camaro Intake Plenum Gasket repair
AUSTIN2020
2002 Camaro, 128K, 3.8
What is involved in repairing - 2002 chevy camaro Intake Plenum Gasket repair ? Is this very detailed? can this affect the timing, etc
Oct 25, 2007 at 6:51 AM
SERVICE WRITER
  • 9,123 POSTS
No affect on timing , not an impossible job for most, just time consuming and spec are required. A manual would be smart:
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Why replace it?
Oct 25, 2007 at 10:03 AM
AUSTIN2020
[quote:374443a810="Service Writer"]No affect on timing , not an impossible job for most, just time consuming and spec are required. A manual would be smart:
Why replace it?[/quote:374443a810]
Well, I took it in because I could smell the antifreeze (burning) The mentioned it was the intake gasket (after doing a pressure test but, after looking at my manual it looks as if the water pump is right in the front vs side. Would it be the intake gasket ?
Tim,
Oct 26, 2007 at 1:35 AM
SERVICE WRITER
  • 9,123 POSTS
I don't know I can't see it. Some tell tale waterpump leak signs are a line on the hood where coolant is slung, rusted pulley. The 3.8 motors are more typical of a intake manifold it self going bad from poor design.
Oct 26, 2007 at 3:57 AM
