You got multiple problems-Get the alternator load tested to fix your low voltage-it should be 13.5-15.5 if the alternator is doing its job.
Also, sometimes this camaro wont start
Could be a problem with ignition switch, starter enable relay,clutch switch, pass key decoder module and starter itself
SPONSORED LINKS
Thursday, February 26th, 2009 AT 6:32 PM
