1989 Camaro Steering Column
D. SHUMAN
I have a 1989 Chevy Camaro with a 2.8 V6, manual transmission, with 140,000 miles. I've had to replace the steering column twice, (tilt) because something keeps breaking inside. (Flops around, won't lock in place). I think this might be a common problem because it is next to impossible to find one.I'm told this column fits this year only. Is there a column from another year or car that I can use and fit it for this car? As long as the wiring is the same or close, I can
mechanically get it to work. Please Help!!!!!!!!
Nov 15, 2007 at 11:11 AM
BMRFIXIT
  • 19,053 POSTS
is it broken or its loose u can fix it remove horn pad disconect electical then remove retainerand jam nut remove steering wheel remove shaft lock ring remove turn signal cam then upper spring unscrew turn signal and then gently pull wires up and work your way down
https://images.2carpros.com/forum/automotive_pictures/99387_camaro_3.jpg
after vremoving # 17 look inside round hole loose screws remove it lock tight on it and reinstall it long put it can be done good luck
Nov 15, 2007 at 11:49 AM
