1997 Chevrolet Camaro Loose Window Seal
PAR4DCOURSE
I have a '97 3.8 w/100k on it. When the previous owner had the passenger side window motor replaced (big surprise) the mechanic left the outside rubber strip between the top of the door and the windw loose. This has been my thorn in an otherwise great car.
I need instructions or a diagram on how to remove the door liner to get at it. It has 5 or so regurlarly spaced clips on the strip but in a year of off and on trying I still can[t get it fastened.
Any and all help appreciated.
Mar 21, 2007 at 6:16 AM
MERLIN2021
  • 17,250 POSTS
usually you remove the window crank or power switch remove screws holding the grab handle and just put a flat screwdriver between the panel and the door and pop the clips out!
Apr 17, 2007 at 2:41 AM
Suggested Repair
Remove the window crank or power switch and the screws holding the grab handle. Insert a flat screwdriver between the door panel and the door and pop the retaining clips free so the loose outside window seal strip can be refastened.
Conversation Summary
The owner of a 1997 Chevrolet Camaro with a 3.8 engine says the outside rubber strip between the top of the passenger door and the window was left loose after a window motor replacement. Clips on the strip will not stay fastened, and the owner wants door-liner removal instructions. The expert advises removing the window crank or power switch and grab-handle screws, then using a flat screwdriver to pop the panel clips.
