Clicking? Or nothing at all? If you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good! That is if the battery test 12 volts! Lights work?
SPONSORED LINKS
Sunday, September 6th, 2009 AT 6:53 AM
