1977 Chevy Camaro engine wont start
MAYHEWCA
  • 1977 CHEVROLET CAMARO
Engine Mechanical problem
1977 Chevy Camaro V8 Two Wheel Drive Manual
i just got done replacing camshaft in my 350 chevy small block. I put everything back together and now it wont start. The starter engages and the enine just sounds like its spinning. All of the belts are spinning like they should be and I took off one of the valve covers and the vavles are moving like they should be. Also there is spark. I dont know if I wired the spark plugs up wronf or compresion or what. Thanks for the help
Sunday, January 31st, 2010 AT 11:24 AM
When you replaced the camshaft did you put engine no.1 piston on its compression stroke/TDC and line the cam and crank markings and rotor point to no.1 cap tower-If not your valve timing is off
Sunday, January 31st, 2010 AT 1:00 PM
