1967 Chevy Camaro car wont stay running
FIREFIGHTER665
  • 1967 CHEVROLET CAMARO
Engine Performance problem
1967 Chevy Camaro V8 Two Wheel Drive Automatic? Miles
Hi, my car will not stay running, as soon as I take the jumper cables off the positive pole from the car ive used to jump my camaro it dies almost instantly. Ive replaced the battery and had the alternator checked and the auto parts store said it was fine. Dont know what else to do. Thanks
Thursday, January 21st, 2010 AT 5:30 PM
Get the alternator reload tested and check the fusible links
Thursday, January 21st, 2010 AT 6:56 PM
RICHIEI
My suggestion is to remove and clean the negative battery cable where it bolts to the engine, usually at the water pump. I believe the car cannot run because it does not have a ground for the spark.
Wednesday, April 7th, 2010 AT 1:48 PM
Related Engine Not Running Content
