Hi, no don, t change back this system will be much better. If you had no probs before the stud turned, then take your alternator back and get a diff one. If their was no prob before that. There is no other option. Billymac. Check the connection at the starter clean and tight check the connection at the batt clean and tight. Remove cable from alt and connect it to bat pos if starts new alt. The pos cable should go directly to the starter. Billymac
SPONSORED LINKS
Thursday, March 26th, 2009 AT 5:55 PM
