1996 Chevrolet Blazer Idler Arm Replacement Fix
good luck
Suggested Repair
Replace the worn idler arm at home with a pickle fork, wrench, and socket: unbolt the frame mounts, remove the center-link nut, separate the joint with the fork, and reinstall the new arm. Parts and the fork are available at auto parts stores. As a short-term option, disconnect the arm from the center link, turn it clockwise until tight, and reattach; that may last about 10,000 to 20,000 miles.
Conversation Summary
The owner of a 1996 Chevrolet Blazer with about 160,000 miles was quoted roughly $200 labor and $100 parts to replace a severely worn idler arm and asked if the job is a moderate DIY. Experts said it is simple: remove two frame bolts and the center-link nut, then use a tie-rod/pickle fork between the dust boot and center link to separate the joint and install the new arm. A temporary fix is to tighten the existing arm by turning it clockwise after disconnecting it from the center link. The tool and part can be bought at a parts store.
