fuel injectors
CHEVROLET BLAZER
KEITH66
I have a 1999 chevy blazer, 4.3 l with 130000 miles on it. It cuts out upon acceleration and I have been racking my brain trying to figure out why. The fuel pump is fairly new and I believe that I replaced the press reg too. Fuel filter, plugs, wires, cap, rotor, and coil are all new. Last summer I had to replace the intake gasket and while it was apart I cleaned eveything real good. Today I cleaned the IAC and the pcv. The only thing I can think it could be is one or more of the injectors but how do I check them on this type of system (CSEFI)?
Mar 26, 2007 at 1:29 PM
BOOTDOG
  • CERTIFIED EXPERT
  • 665 POSTS
you'll need to hook a scan tool using the OBD-II connector, and hook a fuel pressure gauge to the fuel rail. using the scanner you can pulsate the injectors one by one and monitor the gauge to see if they're operating properly. i know everyone doesn't have a scanner, but that the way to go.
Mar 27, 2007 at 10:18 AM
KEITH66
Thanks for the tip Bootdog. Unfortuneatly I will have to take it to some one because I do not own a scan tool.
Apr 1, 2007 at 8:52 AM
