I have an 88 Blazer S10 and it began to slow down gradually then died on me on the freeway. I disconnected the line from the tank to check the fuel pump and it spit gas out when I started the engine. I replaced the fuel filter in case it was clogged. It will start once and then die and not start again. What could be the problem? I also recently replaced the radiator because it was cracked and drying out very fast, but it started losing all the water again after about a month with the new radiator in. Any help is appreciated. Thanks.
Sid
Sid
Dec 9, 2006 at 11:10 AM
