The Blazer would not start and no fuel was being sent to the throttle body. I replaced the fuel pump and the Blazer starts fine now. But the gas gauge reads past full with the key on or off and the oil pressure gauge reads max when cranked. After turning off the engine the oil pressure gauge slowly drops. I can disconnect the fuel sending unit connector near the rear left tire from the sending unit and the fuel gauge goes even further past full.
Oct 18, 2010 at 1:40 AM
