1999 Chevy Blazer Won't Start
TBLAZE20
i have 99 chevy S-10 blazer 4wd, 4.3L v-6 auto matic tran, 114,000miles, My blazer wasn't starting i pulled the old starter and had it check and it was bad, got a new one and replace, and this was won't start the blazer, took that starter back and got a brand new start not reman, and now the blazer still won't start. i have checked all connection the the starter and battery, would you have any ideas or know what steps to try and troublrshoot this problem
Sep 11, 2007 at 5:10 AM
DENNYP
  • 1,824 POSTS
check crank fuse,ignition 40amp fuse,and starter relay.
https://images.2carpros.com/forum/automotive_pictures/102900_starting_1.jpg
Sep 29, 2007 at 4:06 AM
Suggested Repair
Check the crank fuse, the ignition 40-amp fuse, and the starter relay.
Conversation Summary
The owner of a 1999 Chevrolet S-10 Blazer 4.3L says it will not start after replacing a bad starter twice, including a new unit, and battery and starter connections were already checked. The expert advises checking the crank fuse, ignition 40-amp fuse, and starter relay.
