1995 Chevy Blazer Check Engine Light
EZSTRT
  • 11 POSTS
what and how do i get my codes out what tool where can i get it and can i just count the clicks from the light? I have 190,000 on the truck and the only thing i have done to the motor is the K&N cone air filter kit but truck starts but has lack of power seems to heitate and run a little rough ideas?
Jul 12, 2007 at 6:50 PM
  • 75,988 POSTS
Try the diagnostic connector underneath the dash panel jumper A to B terminal and then count the flashes. Then comeback with the codes. Some 95's are OBD2 system.
Could also be a clogged exhaust system-The Cat
Jul 13, 2007 at 12:16 AM
Suggested Repair
Jump terminals A and B on the under-dash diagnostic connector and count the check engine light flashes to retrieve codes. Some 1995 models use OBD-II. Also check for a clogged catalytic converter or restricted exhaust, which can cause low power and rough running.
Conversation Summary
The owner of a 1995 Chevy Blazer with 190,000 miles asks how to retrieve check engine codes and whether the light flashes can be counted. The truck starts but lacks power, hesitates, and runs roughly after a cone air-filter install. The expert advises jumping A to B on the under-dash diagnostic connector and counting flashes, notes that some 1995 models are OBD-II, and suggests a clogged catalytic converter as a possible cause.
