1998 Chevy Blazer Dies When Accelerating
JIM
Suggested Repair
Check fuel pressure (should be 55-62 PSI) and leave the gauge connected to see if pressure bleeds down; if it does, the pressure regulator may be bad. Also watch the oil pressure gauge when the stall happens—if oil pressure drops and then the engine dies, the fuel/oil pressure switch may be bad.
Conversation Summary
The owner of a 1998 Chevy Blazer with a V6 and 94,000 miles reports that the engine dies when accelerating after stops or on hills, as if the key were turned off. It always restarts, sometimes after several cranks. The battery light comes on when it dies, but the battery and alternator tested fine. The expert recommends checking fuel pressure at 55-62 PSI for bleed-down, which may indicate a bad pressure regulator, and watching the oil pressure gauge; if pressure drops as the engine dies, the fuel/oil pressure switch may be faulty.
