2000 Chevy Blazer Battery Light On
MHEMP
2000 Chevy blazer mileage: 85000. Battery light comes on and stays on after vehicle is running. It starts fine and everything, What would cause my light to come on and stay on? The battery was purchased in mid 2003. Thanks for your help
Jun 24, 2007 at 1:46 PM
E40WATER12
  • 522 POSTS
I would get youre charging system tested, Youre alternator could be giving you the warning sign its going to quit soon.
Jun 25, 2007 at 7:53 PM
MHEMP
[quote:f21d4eefb6="e40water12"]I would get youre charging system tested, Youre alternator could be giving you the warning sign its going to quit soon.[/quote:f21d4eefb6]
My air-conditioner and radio and lights are on with no signs of power drainage.
Jun 25, 2007 at 11:48 PM
Suggested Repair
Have the charging system tested. A battery warning light that stays on while the engine runs often means the alternator is beginning to fail, even if accessories still work.
Conversation Summary
The owner of a 2000 Chevy Blazer with 85,000 miles reports that the battery light comes on and stays on after the engine is running, although the vehicle starts normally. The battery was replaced in mid-2003. The expert recommends testing the charging system because the alternator may be failing. The owner notes that the air conditioner, radio, and lights still operate with no obvious power drain.
