1997 Chevy Blazer No Start Dash Dead
JOHNBUKO
  • 9 POSTS
my friend has a 1997 chevy blazer 4.3 liter, 110,000 miles. turns over won't start. sounds like bad fuel pump. turn the key and instrument panel does nothing. battery is good, headlights, power windows, interior lights work fine. won't shift so i override electronic shift lock by pushing the lever down by the shifter and put it in nuetral so we can tow it. low and behold the intrument panel lights up and the vehicle starts right up. put it back in park, turn it off and it has same problem. is the problem in the ignition, shifter or what? i have asked some L1s at work about this one and they aren't sure either. any advise would be helpful.
Dec 12, 2006 at 1:26 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds more like a power supply problem.I would start with the power leads at the battery.GM had serious problems with leaking batteries,the acid creeps down the cable corroding it from the inside out.There is also a power distribution center, check all fuses and relays for proper operation.Then test the ignition switch for power out when in the "on" position. If the dash doesnt light up the PCM wont either. Good Luck
Dec 18, 2006 at 12:06 AM
Suggested Repair
Check the battery power leads for internal corrosion from leaking battery acid, inspect fuses and relays in the power distribution center, and test the ignition switch for power output in the on position. If the dash does not light, the PCM may not be powered.
Conversation Summary
A 1997 Chevy Blazer 4.3 cranks but will not start and the instrument panel stays dark, while lights and accessories still work. Overriding the shift lock and placing it in neutral makes the dash light up and the engine start; returning to park and shutting it off brings the problem back. The expert suspects a power supply issue and recommends checking battery cables for internal corrosion, fuses and relays, and ignition switch power in the on position.
