1997 Chevy Truck fuel pump
JEFF 24
  • 1997 CHEVROLET TRUCK
  • V8
  • 4WD
  • 180,000 MILES
I just put a brand new fuel pump in with new filters and it is not working does the fuel tank need to be grounded for it to work or what could be causing this problem thanks
Sunday, July 4th, 2010 AT 10:17 PM
RICHZOMBIE
  • 173 POSTS
Check to see if the pump is getting power. The fuel pump needs to be grounded.
Sunday, July 4th, 2010 AT 11:55 PM
Power the fuel pump direct from the battery if it comes on-check and test the fuel pump relay and ECM B fuse, if not check the pump ground circuit
Monday, July 5th, 2010 AT 12:00 AM
