1999 Chevy Blazer Service 4WD C0550
UMPIRE
My 1999 Chevy Blazer with 121,000 miles and 4.3L has the Service 4WD light on. The blazer will not shift into any mode of 4 wheel drive. No lights appear on the switch. However the lights all come on ocassionaly or the correct light will come on. A friend (mechanic) with a scanner got a code of C0550. What is this?
Oct 2, 2007 at 1:05 PM
DENNYP
  • 1,824 POSTS
[quote:0882732f24="umpire"]My 1999 Chevy Blazer with 121,000 miles and 4.3L has the Service 4WD light on. The blazer will not shift into any mode of 4 wheel drive. No lights appear on the switch. However the lights all come on ocassionaly or the correct light will come on. A friend (mechanic) with a scanner got a code of C0550. What is this?[/quote:0882732f24]that code means if you have good power and ground to the transfer case module,the module is no good.
Oct 3, 2007 at 2:55 PM
Suggested Repair
Verify power and ground at the transfer case control module. If both are good, the module is faulty and should be replaced.
Conversation Summary
A 1999 Chevy Blazer owner reports the Service 4WD light and no ability to shift into any 4WD mode, with switch lights that are usually off but sometimes come on. A scan retrieved code C0550. The expert says that if the transfer case module has good power and ground, the module itself is bad.
