Growling noise front driver side - bearing hub replacement?
2CARPRO JACK
  • 11,533 POSTS
Sure sounds like the wheel bearing. Usually if you turn right and the noise goes away, it is the right side bearing. When the vehicle leans it takes some of the load off the inside wheel. Try lifting and supporting the front end and turning the wheel to see if you can hear it or if there is play in it. Common problem for those
Friday, May 14th, 2021 AT 12:13 PM (Merged)
MSWOLKE23
  • 1996 CHEVROLET BLAZER
  • 4.3L
  • V6
  • 4WD
  • 236,000 MILES
My boyfriend recently forgot to tighten the lugs on the drivers side front tire. I drove approximately 30 miles or more with them loose. As a result, 3 studs broke off completely the next day after tightening lugs and driving to work. I replaced the studs and noticed a few days later a grinding and noise. Diagnosed it to be the wheel bearing. I removed the hub and the outer race, I believe its called, was broken off and there was a bearing completely missing inside. Would the wheel bearing failure be caused by the loose lugs? And what else might have been affected by this? Im also replacing upper ball joint.
  • 31,937 POSTS
Probably is a result of the loose wheel nuts, as the wheel was flexing the load on the old bearings may have been just to much, I would as a precaution be checking the other side as well just to make sure that there is no excessive bearing play there as well.
MSWOLKE23
I decided to order the hub for the other side. Now that I know how to replace it all it should be pretty easy. Considering the drivers side ball joint was a bitch to get out. I hammered at that thing for hours it felt like. I think I should replace the shocks too. I feel everything on rough roads. Even good roads feel kindav turbulent. How can I tell if they need to be replaced? That's what makes the turbulence go away right? The shocks?
  • 31,937 POSTS
Replace shocks if there is any sign of oil leaking at all. If gas filled, remove and feel for any slack in the shaft up and down, and pushing down full depression should be hard all the way the car should only rock 1 1/2 oscillations when rocked from side to side and let go, that's rule of thumb measurement, a suspension work shop can do a re bound test as well.
FRANK2009
  • 10 POSTS
  • 1994 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 180,000 MILES
Thanks for any help anyone could give me. My driver side front axle seal went out. So I replaced it, the bearing I didn't think was too bad. But in less then a week the seal went out again. The bearing looks like it comes out fron the axel side. My question is how does the bearing come out? Do I have to take the differential apart? It has what looks like a large nut with a number of teeth on it. That seams to hold the bearing in. Does this come out? If so how? Are there any other reason the seal would go out and not be the bearing?
MASTERTECHTIM
  • 4,750 POSTS
Frank dont touch that nut. Your seal is leaking most likely from either a bad seal, wrong seal. If that bearing was gone your front diff would sound like a cement mixer. I have seen a few times that the seals are installed with the wrong seal, a little too big. Make sure the next seal fits snug to the axle shaft and the axle shaft is not worn where the seal rides. Also make sure the front diff is not overfull. And also make sure the vent tube on diff is clear
FRANK2009
  • 10 POSTS
Mastertechtim
I agree, the autopart store wherer my son picked it up 4 me said it would work. It was different.I say it was not the right size.I'll have to go to the dealer or somewhere to give me the right one.I still have the old one.I was told just because they don't look a like don't mean it wont work.
I didn't think to look at the shaft, if there was anythin g on it it would cut the seal.
IThere was some nose, but it was due to lost oil.
Thanks again
Frank
MASTERTECHTIM
  • 4,750 POSTS
The axle shaft where the seal rides will have a ring worn in it. But its unlikely. My money is on the wrong seal. Sorry for the delay
MASTERTECHTIM
  • 4,750 POSTS
Another note. The seal if you look at it to the right one from the dealer you should be able to see the inside diameter to be bigger on the aftermarket one. There has to be a fairly good size difference because it takes a real sloppy fit for a axle seal to leak. They dont have to be tight to not leak because the oil is so thick. Even if there is a ring groove on axle, the right seal will in m ost cases work
OWLSRKOOL3D
  • CHEVROLET BLAZER
When I push the button to shift to 4wd Hi. The light comes on and it looks like the Blazer is in 4WD but the front wheels do not lock in and turn. It appears the electronic portion is working properly because as I push the buttons it transfers from 2Hi to 4Hi and back when I push 2Hi. Should I look at a mechanism used to lock the hubs or are the hubs bad?
MATHIASO
  • 1,209 POSTS
Check the locking hubs by rotating the brake or rotor slightly and turning the hub selector into the lock position.A click should be hear when the hub engages and the axle should now turn with the hub.
Next, with the still running, turn the selector to the free position.
If it does not work as it should, the hub assembly needs repair.
OWLSRKOOL3D
I believe my hubs are automatic. I don't see a way to lock them on the wheels. I had an explorer in the past that had manual hub locks on the wheels but I don't see those on my chevy.
MATHIASO
  • 1,209 POSTS
Sorry for not been carefull to your input.
Look into the connection between
The electric shift motor and the transfer case.
Or the problem is in the transfer case.
Had the system been scaned?
FUNCK_MASTER
  • 9 POSTS
Hi I would look to the vacuum actuator between the transfer case and the front axle. The older modle are underneith the battery. That could be cause the front axle not to engage.
CHEVY22
  • 1,375 POSTS
Actually the switch on the front diff on that year is electronic, if the switch is working and you can hear the transfercase go into gear, it will most likely be the front differential locking switch, 12 bucks and easy to do
FATALFLAW888
Ok the front wheels are engaged by a motor on the side of transfer case and it is controled by a module that is located behind kick panel on passenger side and you may hear it click when you hit the button but the motor maybe to week to engage the transfer case kind of like a weak window lift motor there is no vacuum actuator that shifts the transfer case im not sure what the actuator is for under the tray but it dont shift the transfer case the motor is what I would suspect if the light is on and no 4x4 engaged I could be wrong but my 2003 is not vacuum operated and it would not make since and it does not have locking hubs or automatic hubs for that matter
