how do i take the pins out of the door hinges?
1999 CHEVROLET BLAZER
116,000 MILES • 6 CYL • 4WD • AUTOMATIC
WICKIC03
how do i take the pins out of the hinges to replace them, all four front hinges need to be replaced but can't figure out how to do the top hinge on either side
Dec 13, 2007 at 9:49 AM
TOBYU
  • 89 POSTS
I use a dremel cut off tool or a mini hacksaw. Cut it bend it so you can hit both ends from the middle out.
Dec 13, 2007 at 6:36 PM
  • 55,224 POSTS
I put a floor jack under the door with a block of wood, then use a large punch to drive the pins upward and replace the pins and bushings one at a time, you will need a helper to hold the door steady while you work. Here is how the job is done while using the spring compressor. Check out the images (below). Please let us know what happens.
Sep 28, 2024 at 11:32 AM
