1997 Chevy Blazer Won't Start
GENIE
  • 1997 CHEVROLET BLAZER
Engine Performance problem
1997 Chevy Blazer 6 cyl Two Wheel Drive Automatic
My blazer will not start. I have changed the fuel filter thinking that was the problem but! It turns over and acts like it is trying to start, but it just won't kick in. What else could it be? A fouled plug? Egr valve? What?
I would appreciate any help that you could give.
Friday, November 14th, 2008 AT 6:06 PM
  • 109,750 POSTS
Hi:
Are you getting spark and fuel to the engine?
Saturday, November 15th, 2008 AT 4:39 PM
RUFFRYDERRD90
[quote="Genie"]Engine Performance problem
I would appreciate any help that you could give.[/Quote
Check and make sure the fuel injectors is getting gas when you turn the key up. Fuel pumps are a common problem for blazers! Try spraying some starting flood into the throttle body and try starting it, if it starts for a sec. And dies then you know it is in your fuel system, if I had to say I would be betting on the fuel pump
Sunday, November 16th, 2008 AT 11:02 PM
