1997 Chevy Blazer Wont start
SOVONA
  • 1997 CHEVROLET BLAZER
  • 4 CYL
  • 4WD
  • 164,000 MILES
My blazer will turn over but wont start. The gauges on dash, rear view defrost and a few other things wont work. Fuel pump is coming on and spraying starter fluid in carberator still didnt kick it over. Checked fuses on inside panel they seem to be all good. HELP
Sunday, November 29th, 2009 AT 6:25 AM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Sunday, November 29th, 2009 AT 6:31 AM
SOVONA
I tried everything you suggested. Checked the coill and there is no spark? Now what?
Sunday, November 29th, 2009 AT 1:32 PM
No spark: Did you check the rest other than the coil if so and if all good think! Computer
Sunday, November 29th, 2009 AT 4:25 PM
SOVONA
Augh!That doesnt sound good! Computer? Wont that be expensive? No, I havent checked the rest yet. Am a woman by herself trying to do this! LOL Quit a experience. So Am trying the easiest I can get by with by myself and with your help! Thank you Thank you!
Sunday, November 29th, 2009 AT 5:24 PM
