Hello, what were the fuel pressure specs, did you use a gage? Do you have the spider fuel system?
Just for kicks, I have bench, no load tested pumps that I knew were faulty. I layed it on the bench, hooked up battery voltage--ground. I was surprised how much gas that little pump held, it throwed gas all over me and everything else, I only did that once. On that particular pump, the brushes were wore down to the nub. I can't tell you the pump is faulty without testing. One you build pressure by cycling the key, you might block or clamp the supply line somewhere, see if the pressure holds?
SPONSORED LINKS
Tuesday, March 24th, 2009 AT 3:09 PM
