THE CAR DOES NOT WANT TO START. WE CHANGED THE FUEL FILTER AND THE GAS IS STILL NOT REACHING THE CARB.
Sunday, March 1st, 2009 AT 12:39 PM
BLACKOP555
MECHANIC
Sure its carburated?
How much fuel pressure is there at the rail. Use a fuel pressure check guage.
SPONSORED LINKS
Sunday, March 1st, 2009 AT 9:13 PM
CHUCKY3981
MEMBER
Your fuel injector spider my be cloged of defective
do you hear a noise when you start it that sounds like a small motor on the drivers side listen for that. That is the pump it my be out. Good luck these are very problum matic trucks
